You can only use this procedure on a switch with boundary-node abilities.Perform this procedure to create all ExtremeCloud SD-WAN learned tunnels in the IS-IS remote area.
By default, Auto-sense creates SD-WAN logical interfaces in the home area.
- In the navigation pane, expand
- Select AutoSense.
- Select the SD-WAN tab.
- Select remote.
- Select Apply.
SD-WAN Field Descriptions
Use the data in the following table to use the SD-WAN tab.
| Name | Description |
| SD-WAN
Area Note: This field only
displays on a switch with boundary-node
abilities.
Specifies the IS-IS area, home or remote, where Auto-sense creates all ExtremeCloud SD-WAN learned tunnels. By default, Auto-sense creates SD-WAN logical interfaces in the home area. You can also configure exceptions for specific tunnels. For more information, see Configure the IS-IS Area for a Specific Tunnel. |
| Sd-Wan Vrf |
Specifies the VRF name that Auto-sense uses for the SD-WAN configuration. On models that support a single active VRF, Auto-sense cannot create the dynamic SD-WAN VRF if an IP configuration already exists. |
